5 second start with. 4.7l engine 2011 Ram, no codes, have changed out fuel filter in the gas tank. Was getting 60psi before and after changing it out, while cranking psi jumps back and forth from 52-56 psi until it starts. changed cam and crankshaft sensors still 5 second start. Any suggestions?
I have a 2021 ram classic 1500 5.7l, every once in a while it’ll crank for a long time before it starts. doesn’t do it at first start up of the day. generally after a short drive or if it’s been sitting in the sun for a while. It’ll crank once and then stop and when I turn the key again it’ll...
I have a 2021 ram 1500 big horn with 5.7 e-torque. It has a long crank before it will start, the shop is unable to find anything wrong with it. They tried replacing fuel pump, but still has the same issue. Has anyone had any issues like this or know what it could be?
