over heating
  1. J
    intermittent heat issue
    i have a 2011 ram 3500, studded and new head gasket. truck runs perfect except every so often it starts to run hot. new thermostat ( 3rd one i have put in, never checked them just replaced them hoping for the best ) new water pump, new engine fan and radiator cap. i can drive the truck for...
  2. D
    Why is my truck overheating?
    I have a 2013 ram 3.6 tradesman (flex fuel) I cannot figure out why it continues to overheat. This is a run down of what I’ve done. 1. Check engine light came on and I got a code P0118 for temperature sensor 2. Replaced coolant temperature sensor. Problem still not fixed. 3. replaced...
  3. C
    3.9L Water Leak-Intake???
    Maybe someone can point me in the right direction as my local shops have no idea on my problem. I have a water leak on my 2001 3.9L it has 82,000 original miles with no major service ever performed that I know of and has been in family for nearly all it’s life. So, I was thinking water pump...
  4. C
    Transmission overheated - possibly still running above normal?
    Hello, everyone! This is my first post here and I'm hoping to get some ideas. I'm pretty sure the answer will be to take it to the dealer, but I'm hoping to get at least some insight. I'm okay mechanically so I suspect I'll understand most of any responses. Sorry for the long post but here...
  5. Zinnmaster
    It all fell apart. Help
    Long story short. My son just bought a 08 ram 4.7 with 85000 miles. Had it about a month and it all fell apart. I get a call from my son saying the truck died while on the freeway. He said engine light came on truck got hot and was pouring antifreeze from the over flow tank. Got the truck towed...
