Does it make sense that a VGR (turbo?) is going out when you watch it go up hitting 30psi when you punch it? Does it make sense the EGR needs replacement? All of these are ideas that have been passed by me due to the following issue:
When I punch the gas pedal, the truck bogs down then kicks...
09 ram 5.7 hemi I did a cam and lifter swap with stage 1 cam and none MDS lifters Witch I deleted the whole MDS system and I put a new timing chain set with new phaser added the VVT lock out in the phaser also but I just took the lock out thinking it was the issue but it wasn't I have checked...
I'm not sure if I'm posting in the right area. I am having problems with my 2014 Ram with a 6.4 motor. I've had three transmissions put in it throughout the past two years by two separate companies, but I keep having the same issues. It keeps burning up gears and often goes into limp mode. I'm...
