Can't find any comparisons between these two plugs, apparently Ruthenium is better for burning a bit more efficiently and also supposedly lasts even longer than the 100,000 plus range.
So of anyone has used Ruthenium and compare them to the Laser Iridiums it'd be highly helpful!
I just recently purchased a 2010 Dodge 1500 laramie Quad cab. The truck has almost 200000 miles on it but the truck is in awesome condition, very well taken care of. Looking to do a full tune up on it and also change out the stock shocks and bump stops, any advice on what to use. General use...
I did the long daunting 16 spark plug change on the truck and decided to finally make a good guide for fellow RAM owners to follow to make this job as pleasant as possible.
The use of a cheap $12 magnetic swivel socket makes this job 100x better and a moving a few extra things really make the...
