speed sensor
  1. S
    68 RFE speed sensors stuck
    Hello! I recently got the code p0734, and i read somewhere here that changing the speed sensors could fix that problem. (truck is a 2012 2500 6.7 68rfe, 160k miles) So, I'm trying to disconnect the speed sensors to change them, but I can't find the way to unplug them. I know i should just press...
  2. G
    2008 Ram Dash Light warnings flashing with no codes
    I have a 2008 Ram 1500 5.7 Big Horn edition. My TPM, check engine, abs, parking brake, check gauges, and tire pressure warning lights all come on at the same time and the speedometer and the tack drop down to zero. Square boxes also appear around all of the gear indicators above the mileage...
  3. A
    Speed issues
    Hoping someone out there knows whats going on with my 2012 Ram 3500, 4x4, 6 speed, 6.7 liter. ABS light on, traction control light on, EM brake light on, speed way, off. All happened at once. Dealer told me my tires are the wrong size so I know they are clueless. Took it to a good shop for...
jimn
