traction control light
  1. Carbary
    2017 1500 parking lamp out message
    I have seen this has been discused before but my situation is slightly different. Just bought this 2017 Ram 1500 Lone Star edition, 5.7 hemi RWD. Parking light out would come on the dash every time you hit the brakes with the light switch in the on or auto position, but not in the off position...
  2. C
    2013 ram 1500 service end message and traction control light
    I have a 2013 ram 1500 with the 5.7 hemi. When I start the truck I get a “service electronic brake system” message. The traction control light is also on and my cruise control does not turn on. Can anyone give me some direction on where to start diagnosing this issue or has anyone had similar...
  3. B
    Service air suspension, electronic braking system? 2017 ram rebel
    I got an alignment and when I left my service air suspension system and electronic braking system came on at the same time and my traction control is stuck off but I left my truck off over night and my air suspension never dropped or lost air it is still at normal ride height, the fuses/relays...
  4. U
    ESP BAS and traction control light flashing
    I have a 2010 1500 SLT 2WD, 5.7L Hemi. I just got it back from the dealership after getting the ignition module replaced. The ESP BAS light has been on for a little bit before this, and it would only be occasionally. However I was driving home from the dealership and it was raining. The ESP BAS...
  5. boothby1952
    Needing assistance
    Needing some ideas for 2012 RAM Express, 5.7, auto...here are the problems I’m having with this truck. Any info will be extremely appreciated. 1. As I’m driving, engine cuts out until accelerator pedal is tapped a couple times. 2. Trac Control/serv4x4 lights come on at same time...
