turn signal error
  1. T
    Right rear tail light issues
    I get a right rear turn signal not working message. The running light works but my turn signal and brake light do not work. Bulbs have been replaced. Struggling with finding the issue
  2. 1
    Turn signals double flashing and solid on dash.
    Hey all. Looking at an issue involving my lights. So I had an issue where the right headlight was dim, and I was also getting a hyper flash on the left, and somewhat faster flash on the right with the dimmed headlight. Running lights worked fine and turn signals worked in the off and running...
  3. internetdel
    Intermittent turn signal error message
    On my 2016 2500, occasionally, I get a message that my left rear turn signal light is out. The flasher in the cab flashes extra fast, but the outside turn signals all work at normal speed -- no lights out. Then, maybe even the next time I use the turn signal, it is all back to normal with no...
jimn
