valve body
  1. Merkaba
    Need advise about transmission problems
    Hello I'm new here this will be my first post I could really use some advise but I will explain a bit about who i am. I'm 51 years old and I have worked on my own vehicles also friends and family vehicles my whole life with pretty good success for the most part so I do have some mechanical...
  2. C
    68rfe valve body HELP!!
    Help! I’m not sure if this valve body cover is cracked or not… I pulled my trans yesterday because I was getting a p0740 code and was going to put a new torque converter in the truck. I took my trans pan off and was cleaning the gasket when I noticed what looks like cracks in the valve body...
  3. chidychi
    Grey VB Solenoid Connector Pin Layout?
    Hey All, Changing my 66RFE Valve Body. Can anyone confirm if the grey connector on the solenoid has the same pin layout as the white one? I'm installing a CHR145 and the Sonnax instruction show the pin layout of the WHITE connector. I get nothing on pins 10 & 7 (overdrive). Just want to...
  4. B
    Would a 2003 3.7L Valve body work with a 2007 5.7 Hemi?
    I am trying to replace my step-moms valve body/shift solenoid in her truck and was able to get one that belongs to a 2003 3.7L ram 1500. I have been trying to search it up and from what I can see they use the same transmission and can work even if they are 2WD to 4WD, all you have to do is...
  5. C
    68RFE issues
    So I’ve got some shifting issues with my 2013 2500 with the 68RFE (go figure). I’ve been doing lots of research and asking around and haven’t been able to figure out what’s going on. Whenever I shift into drive, it takes about 3-4 seconds. Also, when I downshift it takes longer than it should...
  6. RonG
    48RE Shift Issues
    For quite a long time, my 2005 Ram 3500 (Cummins diesel, rear wheel drive, SLT) had been very difficult to get out of Park. I studied "YouTube University", as well as some of the online Forums and decided to put in the "Detent repair kit" from TransGo to correct the issue. What should have...
jimn
