1999 dodge 2500 towing
dodge19995.9
5.9 diesel
hello i have a 1999 dodge ram 2500 24 valve what is the biggest 5th wheel the truck could handle
Stangshcky12
Oshkosh, WI
5.9 Cummins
depends on the cab/bed combo as well as the transmission, rear end gear ratio and 2wd or 4wd
D
dodge19995.9
5.9 diesel
club cab shortbed 5.9 cummins 5 speed manuel trasmisson
RamV10
Western Central NV
V10
Look up the factory ratings for max weight it can pull.
If you want a size you should be able to pull a 10x50 mobile home, at least until the cops catch you. Then a several thousands dollars in fines & all will be good.
Good Luck
Steve58
