2010 known good configuration
kbelfour
Canada
I have a 2010 ram sport crew cab 4x4 , been fighting the bcm config for some time now with alpha. when I first purchased alpha I didn't register or save my original bcm configuration. the wcm defaulted and I've had to start the configuration manually and the bcm keeps defaulting to the European convertible (known dodge safety config). With all that I'm looking for a good configuration to work off of the get my truck back in sync. any help is appreciated.
jws123
nj
your better off towing it to the dealer and having them program everything factory settings. However why did you change your bcm what is your orig issue?
jawzs2
Air Force
South Jersey
I can take a snapshot of mine, but won't be able to get to it until Monday or Tuesday if that will work for you
kbelfour
kbelfour
Canada
Sent you a PM with what I got
I've used your configuration to copy the flag settings , my gateway is still throwing codes but thanks for it. I'm having trouble getting the first handshake so every time my truck hard cranks in the cold weather the truck defaults to the European default
kbelfour
kbelfour
Canada
Any chance you could tell me if you've got auto 4wd with the dial selector , and what type of transfer case is set in your config
jawzs2
Air Force
South Jersey
Yes - I do have the dial, Alfa shows - Vehicle Config 3: Tcase Type: 243
kbelfour
kbelfour
Canada
perfect thankyou ,sorry t bother you again but the is a configurable input 1-7 section and output section 1-14 . do you have anything listed in those sections. I'm trying to nail down this config and I've got no 4wd or command start and there are settings in the input and output for both of those
jawzs2
Air Force
South Jersey
No worries - can you send me a screenshot of where you're looking? It's actually been a couple years since I actually used this, so not as up to speed as I used to be. I'll try to get to it later today
