GaryB66
After much research here and YouTube it didn’t help. I had stop lights, bother turn signals but no running lights to my trailer. Picked up a plug in tester and confirmed it’s the truck. I pulled out the 7 pin/ 4 pin factory installed plug. Pulled everything apart cleaned it all with WD40 And put back. Still not working.
Research showed the running lights are on a separate circuit with a fuse. The problem is there about 4 fuses listed in wiring diagrams showing parking lights. All looked good.
Then as we tend not to do I looked at the manual. It showed a different fuse J14 which is a large square fuse 20 amp.
It’s hard to visually see if burned out so swapped it with my washer fuse J21 temporarily and the trailer lit up like a Christmas tree. Now to track down one of these fuses. Doesn’t look common to me. Canada Canadian tire or Lordco
I am so happy as that was a lot of headache. I started to rewire my trailer thinking it was the problem
Hopefully it helps someone
