2014 Ram 1500 3.6 L Pentastar EGR Valve, I'm having no luck finding any information regarding this.
garycarrick
Winnipeg
Dodge parts could not tell me anything. Does the 2014 1500 3.6 L HAVE an EGR valve? Dodge has no listing. Is it integrated into something else?
Jeepwalker
WI
2012 Reg Cab, 4x4
I see what you mean, I did some searching and I get different reports. Pretty sure there is one. Per a search THIS one came up. Not cheap.
But I can't find where it's located. I have the same engine in a similar yr Jeep. I'm not putting my eye on it either (unless it's under the intake). ...
I better let someone who owns a 2014 chime in.
:happy160:
HuskerRam
Air Force
Tucson, AZ
3.0 Ecodiesel
I believe EGRs didn't find their way into the 3.6L Pentastar until around 2016-2017. If you're running a 2014, you won't have one. Did you get a code for an EGR issue?
G
garycarrick
Winnipeg
Perfect, thanks. just been chasing random weirdness since I had it in to dodge to repair an oil cooler leak last winter. $1200! I changed the plugs recently and found that two of the upper intake bolts were stripped.. (wont torque or tighten properly) so that's the where I'm getting the p2173, p0507 i suspect. All the hoses and connections look good. They also left off the mounting nuts that secure the upper intake, front and back. Good luck getting them to acknowledge it. Had to order a new lower intake to correct the stripped holes so i can fasten it all back together properly. Still under extended warranty, but its funny how all the plastic bits that bolt on aren't covered.
G
garycarrick
Winnipeg
Finally found my p2173, p0507 that at its worst cause transmission codes and limp mode. Aside from the stripped upper intake bolts at the back, I had severely worn fuel injector o rings on the most rear injector. Replaced the lower intake and all injector o rings and now seems to be running well.
ram150082
