TheJLowe
- Apr 9, 2017
- 27
- 4
- 2016
- 5.7L HEMI
Hey Guys,
I just had an oil change done on my 2016 Ram 1500 and the dealership said that my rear differential oil needs changing soon as it is getting dark. I looked online and saw that there appears to be a drain plug in a guy's video. The dealership says only the 2500/3500 have them and that I'd have to take the differential cover off but I clearly see one. I'd rather use the drain plug so I don't have to worry about putting back on RTV/silicon. If I did have to remove it, I'd rather replace it with a gasket opposed to RTV anyways.
My question is, does it do any harm to just use the drain plug? If there were metal shavings or anything in there..I'd presume I'd see them coming out through the drain plug too.
Also, I do need to the additive limited slip. I see some bottles of oil already has it included it says. Can I just use those and not add the limited slip separately? Or do I still need to add it on top of the oil?
