Dbake111
Hi everyone,
This is my first post here but I have used the forum before for tips on repairs I was planning. As the title states I am having a small issue with my 4wd light. It seems to be working properly but in reverse order, meaning in 2wd it lights up, but in 4-Hi or 4-Lo it turns off. I am running out of ideas as to what is causing this.
When I bought the truck the axle seals were leaking and the vacuum lines had been ripped off so the 4wd did not work, but the light was never on. Just a couple weeks ago I went in and replaced the seals, upper/lower ball joints, u-joints, all bearings/bushing in CAD, and vac lines, but I didnt replace the indicator lamp switch, which I just ordered. The switch is the only other thing I can think of and I will be replacing that in the next few days. Does anyone else have any other thoughts or ideas as to what could be causing this? Thanks in advance for all the help!
