05Hemisled
My 05 1500 5.7 is giving me hell. I picked it up with issues for cheap with 73k on it. It had issues with the trans pump and when I dropped the pan there was a lot of clutch material on the magnet so I went and grabbed one from a junk yard.
I swapped the trans in along with new filters and moved over a new line pressure sensor that I had on the old one. I got it together but the truck is stuck in limp in mode with a ton of codes. Even after resetting the codes and having the battery disconnected for about 10 minutes there's no difference.
The codes it's showing are P0700, P0846, P0871, P0876, P0888, and P0988.
Everything seems to be plugged in and I can't find any immediate wiring issues. I swapped the relay with another and there's no difference. Does the PCM need to be reflashed because of the change?
