99 5.9 v8 Engine miss above 3500
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
So about a week ago I noticed when I stand on the loud pedal above 3500 it feels like it starts missing. No codes are present. It otherwise runs great.
1999 Ram 1500
5.9 V8
4x4
The top end was overhauled in 2016, new heads, new plenum gaskets, timing chain etc.
Cap, button, wires, and plugs were new then.
It has a CAI, a more free flowing exhaust system, and a tune.
The tune has been on since July with no issues.
Sitting here at the keyboard wondering what it could be. Thought I'd see what others thought.
Thanks in advance
Fast69Mopar
Have you verified that you have proper fuel pressure?
JimW124
Chesapeake, Va
1999 dodge 2500 diesel
5.9Ltd. Diesel:
Just curious, did it set an engine light or have you attempted to see if it stored diagnostic codes. Fast 69 Mopar could very well be correct on your fuel pressure. Check there first.
Bear_Gibson
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
I have not checked it yet, do these have the test port in 99? Im not under the hood often. Just to check fluids.
It feels like an ignition miss. It's not constant. Maybe on miss every few seconds.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
'99 has a test port on the driver's side rail. I know because I have a '99 and I've tapped it more than once.
How old is your catalytic converter, assuming you have one installed? It could be in the beginning stages of becoming clogged, and it's only downhill from there.
Bear_Gibson
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
I know it's not the cat. I did that a couple of years ago. it has a magnaflow y pipe and a spun converter. Friday after waiting for traffic to turn I leaned into it pretty good and got a heavy miss that cleared up after I let out some. Engine light flashed, I scanned it and a a pending cylinder 4 misfire code. So today I pulled the plugs, which I think I replaced in may of 16 when I did the heads. it had about .050 gap, instead of .040. I checked them all and found they were all above .040. So I re-gapped them. I plan to replace them as soon as I can get the boat out of the garage. What do you think? Is .050 more than the stock coil can handle. I have an OE style msd coil for the truck, I just never installed it. This miss feels like ignition to me, too harsh and sudden to be fuel.
Yeret
5.9 Magnum
OEM plug gap is .040". Wouldn't recommend going wider with a factory coil. The MSD coil would probably fire .050" gap fine, but general consensus is aftermarket, high-output coils yield no benefits in our engines.
Bear_Gibson
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
I alway wondered about those coils.
.050 was the worn gap. I think they are worn .010 over. I put them back to .040 but it did
If new champions don't fix it then I plan to look at the distributor cap
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
My 2000 5.9 seemed to go through distributor caps like they were candy. Especially if I replaced with a cheap aftermarket....which I usually did.
Bear_Gibson
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
I remember having trouble with my 318 Dakota's cap before, but I don't remember the symptoms. It's been almost 10 years since that happened.
El Huapo
California Foothills, USA
2019 4X4 Warlock 1500 Classic DS w/3.55 LSD
V6 flex
Finding proper fuel pressure sitting still with no load is not proof of getting enough fuel volume when running under load. A partially plugged fuel filter may pass enough gas (oops) when idling or running easy, but when asking for more power (read fuel), it may be restricting the flow enough to reduce power. A weak fuel pump might do the same.
I had a Spitfire that ran great when the going was easy but wouldn't climb the hills in 3rd or 4th. After much head-scratching, a fellow on the Triumph forum mentioned that some of these beauties had a second fuel filter behind the seat, in the trunk. Yep, there it was, I replaced it with tubing and the car came alive. I love these forums!
