Auto Running Board Part
Machete
This part slides into the groove underneath the auto running boards. The hinge mounts to it. I snapped the bolt taking it apart replacing my running board motor and messed up the hole trying to extract it
Couldn't find the part number online and my local dealer told me I'd have to purchase the entire board at $691
Daw14
South Florida
You may have to fabricate it, or find a shop that will do it for you.
It does not appear that it would be very complicated to make if you’re mechanically inclined.
commander
Myrtle Beach S.C.
2024 1500 Limited Crew Cab
Agree with daw14, you might also be able to drill & tap a new hole with either a SAE tread or Metric, would probably need to be a little bit bigger in size.
JT
DITRIO
