Cold air blows on drivers side and hot air blows on passenger side when trying to use ac
chocolatestar
Arkansas
I have a 2017 ram 1500 bighorn 5.7 hemi. When I try to use my a/c it will blow cold air on the drivers side and full heat on passenger side. I have replaced the blend door actuator but I don't feel that the original was malfunctioning. Looking for any information on what to look at in order to fix this issue.
jws123
nj
It really only can be a blend door issue if the system was low on refrigerant the drivers side would be warm and pass cold. What blend door actuator did you change? You can also move the door manually with the actuator off to see if the door is good once you find the correct one.
diymirage
Banned
My wife had the exact same issue with her charger...turns out it had dual zone HVAC
C
chocolatestar
Arkansas
So does that mean the cluster around the dash screen needs replaced?
C
chocolatestar
Arkansas
Because I do have issues with it not blowing air where I select it to. It just blows where it wants really.
C
chocolatestar
Arkansas
I have also researched that it might be the hvac control module that is located on the passenger side towards the door behind the glove box.
TMFMK
