Finally got my HBS 2" Kit installed - pics and general install experience included
OneShot201
2012 1500 Express - Mineral Gray
Finally got time to put the Hell Bent Steel 2" kit on last weekend.
I am very happy with how it looks, and am looking forward to being able to get larger tires on.
I went with the 2" kit to try to minimize problems with vibrations etc.
I intend to run 275/65 r20 A/T tires on aftermarket wheels with -12 offset (already purchased used Eco 826 Max 6's in chrome, just saving my allowance for the tires :) ).
The install is a bit of a PITA, took us about 2.5-3 hours for the first side, then only about an hour for second side. Not terribly difficult but still some work.
The instructions clearly state that no spring compressors are required for the install, but that is flat out untrue. Not needed for disassembly but absolutely needed to reassemble. We used the cheapo Harbor Freight ones I borrowed from a buddy. Remember, you are lengthening the strut assembly by 2+ inches, impossible to reinstall without compressing the springs first.
I would definitely advise getting the deep sockets the instructions recommend, not common sizes either, 21 and 24mm. Huge help to have them.
A word of warning, we cut the CV boot on the drivers side accidentally during reinstall. Very painful mistake, almost $200 repair cost, done at the same time as the alignment. That's using the OEM boot from Mopar, not a wraparound replacement style.
The alignment is a must, the numbers are thrown way out of wack after leveling, I paid $89 for the 4WD alignment, the last pic is the alignment report and you can see just how out they get.
Very doable install for anyone with the slightest bit of mechanical ability, and well worth it imo. Looks like a different truck even with the stock wheels and tires. The "Before and After" pic is the easiest to see to me, in person it makes a world of difference.
Enjoy the pics!
Before
Before and After
After
Alignment Sheet
1500ram12
5.9L Cummins
I found out during the install that it was easier to unbolt the upper control arms and brake calipers. That gave you all the extra play to get the strut assembly back in
Sent From My DROID RAZR MAXX Using Tapatalk 2
OneShot201
OneShot201
Yeah you're right, that would have worked, we didn't take that step.
quietpeen
2021 TRX
Hellcat
looks great man!!!!
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
spiffy
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
Very nice.. It makes a good difference. Can't wait to see the bigger tires on it
Stroked
Beloit, Kansas
Looks good! I hate how low these trucks sit in the front from the factory.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Nice install I'm looking at doing this also, so how do you like it so far?
mrtosh
Looks great bud! How much did the front "settle" after the alignment?
Coasty993
VA
HEMI 5.7
Good afternoon. I am trying to install a Trailmaster Leveling Kit on my 2007 1500. I got everything apart except that I could not get the bottom bolt for the stut. I took the nut off the end but couldnt get the actual bolt out. Any suggestions?
Jason
quietpeen
2021 TRX
Hellcat
Are your trying to pull it out or turn it out? Both of mine came out like they are screwed in
mrtosh
X2^^. Otherwise have someone push down on the LCA and jiggle it out. Depending on where you are the bolt maybe seized in the bushing sleeve if its rusted enough. Let's hope that's not the case.
Firefighter-Diff
any drive difference
since the install have you noticed any drive difference at all? on the highway,road,in 4x4?
Firefighter-Diff
additional costs
Did You have to buy any additional parts to go along with this kit i was reading up on HBS.com that they reccomend buying other products did you end up buying anything else thank you in advance
