Fuel hostage wheels ....... Need some help!!!!!
mchico
Ontario, Canada
hemi
Hey guys!!!!
Im new to the forum and its an amazing place. I have a 2011 ram 1500 4wd sport with bilstein 5100s n the front cranked. I want to put on fuel hostage wheels 20x10 with 33x12.50x20 toyo o/c mt. i need help determining what neg offset to go with. Ive searched all the forums and the best ive found was quietpeens sick rockstars. Any input and pics plzzzzzz
that white kid
I dont know about the negative spacing but i would go with 35 i wish I did 33s just look to small
mchico
mchico
Ontario, Canada
hemi
really!!!! With 20x10s with -24 offset nt sure bout the backspacing but 35s will prob rub..... thats y i was thinking the 33s.......u have anu pics??
4x4Hemi
Edmonton, Alberta
35s will fit man,
these are my 35x12.5x20s on a 20x9 with 0 offset, they rub a tiny bit on the inner fender, but not even enough for me to care enough to trim it. im not sure what offset that would equal in 20x10 though,
monettejb
2018 Hydro Blue Edition Ram 1500
Greenville, NC
I just ordered -24 offset on my 20 x 10 XD Diesel's because its the only offset they make them in. From what I've found they may rub a little but they will stick out further. I like the stance. Im going to go with 35 x 12.50 also, but Im doing the 2.5" level and the 1.25 inch body lift combo.
mchico
mchico
Ontario, Canada
hemi
thx for the pics. i was orig thinking the 35s but i wanted the 20x10s with -12 offset so they stick out a bit further then the 9s with a 0 offset........but i only got the bilsteins cranked n 1.5" spacer n the rear. too many options lol ... not sure if the -12 20x10s n 35s will rub
2serious
long island
I have 20x9 hostages. Don't know the specs on em tho. Is it on the back of the rim?
quietpeen
2021 TRX
Hellcat
35's on 20x10 with –24mm backspacing will rub with only a level. Because they stick out so far they will rub when turning.
mchico
mchico
Ontario, Canada
hemi
not sure if they are on the back of the rim. Thats why i wanted to go with 33s ...... no rubbing. So i wont have any issues with 20 x10 , -12 or 24 offset with 33x12.5s
quietpeen
2021 TRX
Hellcat
I am running 33x12.5x20 on 20x10 with – 24mm offset. I have no rubbing at all
mchico
mchico
Ontario, Canada
hemi
i seen your pics .......looks amazing !!!!!!!! what back spacing do you have and what fender flares are u running laramie or 2500?
quietpeen
2021 TRX
Hellcat
thanks, the backspacing is 4.5" and i am running the 2500 flares
that white kid
and also I would do the 3in body lift instead of the 1.25 you cant really tell that big of a difference with that imo well thats if your going for height but if your going just for clearence then go with the 1.25
68Cudaconvert
