Get Rugged Style with Air Design Fender Flares and Spoilers
carid
Cranbury, NJ
Hemi 6.1
Hey truck owners,
If you’re thinking about giving your truck a fresh look and added protection, Air Design’s lineup of accessories is definitely worth checking out. The Super Rim™ Fender Flares provide tough protection against road debris, mud, and gravel while giving your truck a stronger, more aggressive stance. They're built with a secure mounting system, reducing vibration and eliminating potential damage to your truck’s finish.
Another great add-on from Air Design is their Fender Vents, designed not just for style, but also to improve airflow and cooling efficiency. These vents help extract hot air from under the hood and lower air pressure in wheel wells, improving overall aerodynamics and performance. It’s a practical and stylish upgrade you'll definitely appreciate on the road or off.
And don’t overlook the rear of your truck—Air Design’s Super Rim™ Tailgate Spoiler and Tailgate Applique add sporty style and better aerodynamics with an easy, drill-free installation. The spoiler smooths airflow over your truck's tailgate, while the applique provides a custom look and premium feel. With these upgrades, your truck will not only look sharp but will also be better protected for years to come.
Air Design® - Super Rim™ Fender Flares
Note: Select your vehicle when adding to cart to confirm fitment
Features:
  • Mechanical fixation to the body line, to eliminate all vibration and paint damage
  • Mud flap "anti-splash" contour that widens the bottom of the flare, protecting the sides of the vehicle
  • Advanced aerodynamic mud flap integrated into air design fender flares, stops rocks and road debris from chipping you vehicle's paint
  • Parts are molded using high-tech multilayer black ABS senosan polymer and top coated on their surface for extra UV protection and strength using a German OEM approved 2k satin black paint
Air Design® - Fender Vents
Features:
  • Made to accessorize your vehicle and give it a stylish upgrade
  • Help reduce high pressure air that builds up in the wheel wells
  • Will aid in providing additional cooling to the engine area
  • Crafted from superior-grade materials for enduring service
Air Design® - Super Rim™ Tailgate Spoiler
Features:
  • Provides unique level of personalization and improved aerodynamics
  • Visually and technically, offers elegant design
  • An outstanding premium-sport rear end upgrade
  • Installs on the rear door of your truck in matter of minutes with perfect fit and no drilling is required
  • Expertly manufactured from the highest grade materials
  • Made to guarantee exceptional reliability
  • Will provide a reliable solution for off-road applications
Air Design® - Super Rim™ Tailgate Applique
Features:
  • Smart way to individualize and restyle your truck’s rear end
  • Manufactured applying Air Design’s Super R.I.M. technology
  • Ensures outstanding reliability and incomparable quality
  • Provides a precise fit that makes installation a cinch
  • Beef Up your Truck. Improve performance and appearance
  • Quality Materials. All components are manufactured out of high impact multilayer ABS
  • Extra Protection. Provide added protection against road debris, mud and chipping
  • Easy to Install. Automotive grade adhesives make this an easy and long-lasting installation
  • Rust Free. Install without drilling a single hole on the Sheet Metal. Forget about rust and those unwanted gaps!
  • Removable. Can be easily removed to return your Truck to Stock condition
  • Factory Painted: Satin Black Finish, Install Ready. Factory applied OEM UV Stable Satin Black 2K German Paint Finish
  • This finish will prevent any premature color fading or material cracking due to the harmful rays of the sun
  • Factory applied industrial 2K German primer
To learn more about the Air Design brand, go to the page below:
carid
carid
Cranbury, NJ
Hemi 6.1
Right now is the perfect time to grab premium truck accessories from Air Design at CARiD.com—during our special sale, you’ll save 10% on your purchase! From March 7 through April 15, 2025, enjoy reduced prices on high-quality upgrades like fender flares, tailgate spoilers, and stylish fender vents. Prices are already marked down, so don’t miss your chance to personalize your vehicle and save big!
Browse the full catalog of Air Design products here:
Check out other active promotions and coupon codes:
Gregf
