Headlight Dust Covers
colport833
Ontario
2022 Ram 1500 Classic
hemi
Hi..just got these covers made...when things warm up..will be installing/trying them. This should solve Led fan fitment issuesreceived_581012910572295.jpegPXL_20221111_002705853 (1).jpg
dandydog250
Do you have a file for them? I'm struggling with the same issue
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Color me confused. Closing off a cooling fam in a small enclosed area.
regal81455
Illinois
I did not use anything yet
I think he was asking the OP....
And yeah PLA would be a huge waste of $$ and time. PETG, ABS, or PLA+ at a minimum.
Finally, I would also be interested in said .STL if it's something that could be acquired easily. Might not ever need it but I also don't wouldn't want to spend the time with protos if possible. Fingers Xd!
dandydog250
My bad. . .
I'm having a friend print some up 100% infill, and yes I do believe it is out of pla. Which should be fine.
Halogen bulbs get a lot hotter than the driver on an led, need the cover to keep out the moisture I thought the one cap being almost all the way on would be good enough it is not.
Justthebutler
BC
2017 Ram 1500 SLT
I spun mine on locking one side in and resting on the led fan, its on there solid and it gives it some air to cool off.
It makes no difference in town but on long trips when they get hot it allows them to cool and prolong the life of the bulb.
And I haven't had any moisture or dust yet.:favorites37:
regal81455
Illinois
My bad. . .
If it is PLA even at 100% infill it's going to lose it's shape pretty quickly once engine bay and summer heat get to it.
PLA is good for prototyping something like this but you're gonna want this printed in PETG or ABS eventually.
clifford15
RI
CTD
PLA is OK up to about 130F. I found that parts in direct sunlight stay stable if made from or painted a light color. I have a silver painted mount on the dash of my RAM and it hasn’t melted. Going on 2 years. On the other hand I have a black emblem mounted outside and it deformed from the hot sun. ABS and PTEG are definitely better for higher heat applications.
Hemi395
Cape Cod MA
You should sell those, I haven't found one that actually fits right...
PaleFlyer
Charlotte NC
No...my guy used PETG? thats all I know
PLA is the "easiest" to print, but basically has the temperature range of a late 2000's Honda Civic Sunvisor.
IE gets above ~120F, and gets soft to the point it basically remelts. So in a vehicle that gets parked outside ever in the spring/summer/fall, the print would not last.
PETG is supposed to be good to ~176F before it hits the "glass transition point" (when it gets too soft), so should be fine.
bmireault1980
