Hello ! I have a 2022 ram limited 10th anniversary ! when I start the engine the 10th anniversary should show on the dash but it does not !
ioani
ohio
ecodiesel
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I would guess that you will find the answer in your radios menu
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I'd be asking this question at my local dealership. If I had just bought it I'd be speaking to the sales rep who sold it to me. I've had lots of annoying little things like this taken care of by contacting my sales rep.
I
ioani
ohio
ecodiesel
I did look in the radio menu and I could not find anything !
2020PW
East coast
It maybe built as a regular limited and had the emblems added.
JoeCo
NY
Saw this problem mentioned on the other forum by a few owners of 10th anniversary limiteds, it can be changed in alfaobd to get the correct screen showing. Just programmed wrong from the factory or something. Dealer should be able to fix this, or the owner with the proper alfaobd setup.
JoeCo
NY
That should be easy enough to tell, what interior does it have? Only the 10th anniversary got the sea salt/blue interior for 2022s so that would be a clear indicator, or of course what is on the build sheet as well.
DeckArtist
Elmo, Tx
There's one in every crowd.
To the OP...definitely ask the dealer about it, they can solve it for you.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Iowhiner:
You look like a new poster. I really feel sorry for you, NOT, why would even post about this so-called problem.....
Now, I think I've seen it all.........:(
How old are you, spoiled brat.
Whoa, easy gunpowder. No need to get nasty about it. It's a perfectly legit question.
Kickboxer
ND
5.7 Hemi-non-Etorque
This is not how you start out new on a forum....out of line........
Fediej
Wisconsin
EcoDiesel
Iowhiner:
You're out of line. If the Newbie isn't following proper etiquette let the moderators and admins handle it. Don't be such a donkey.
Kickboxer
ND
I just call out BS when I see it. If you don't like that then too bad.............
matruck
Dallas
EcoDiesel
I had the same issue. It is NOT a radio setting. It IS a setting in the BCM that can be changed via AlphaOBD. I *think* Tazer DT can do it also. And of course, the Dealer can do it too.
I
ioani
ohio
ecodiesel
thank you !!!
Wulf
United States
While it might be possible for the end user to do it, with either Alpha or Tazer, if it is something that the truck *SHOULD* have had enabled from the factory/dealer, even though a pain in the, well, part you use when driving said truck, then the dealer should be the one responsible for fixing it.
