How big of a level do I need?
chall91m
I have a 2008 Ram (obviously) and was wanting to level it. It's on stock rims (A/T tires) with 4WD. I need to know what size leveling kit I need. I don't want to buy one that is to big in the front and give my truck that dumb "Cali lift" look, nor do I want to be short by an inch or a half. Can someone point me in the right direction? Here's my truck info if it's any help.
2008 Ram 1500
4WD Laramie
285/70R17
crazykid1994
Measure top of wheel to bottom of fender front and back
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
As crazykid said, you need to measure your own truck to determine how much rake you have stock. From there you can determine how much you need to lift the front end to bring it up to level. You'll likely want to retain about 0.5" of rake to avoid looking nose high.
I would also highly recommend Bilstein 5100 adjustable front struts over a spacer type leveling kit as it will give you a better ride quality and is simply better for your suspension.
blackbeautyhemi
Lewistown, PA
Yes the bilsteins are highly recommended over the spacers. Ride much better and only cost a lil more than the spacers.
usocazy
San Antonio, Texas
Hemi 5.7l
I don't mean to hijack the thread but had the same question on a suspension thread I kicked off. Are Bilstein 5100s all you need to level an 04 Ram 2500 2WD?
brandonjansen
ameer73
