How can I fix this?
jgruberman
EcoDiesel 3.0L
So I was loading a TV into my truck during Xmas and it caught the ceiling and messed up the foam maybe under the liner? Anyone know how I can fix this easily?
The cloth isn't ripped, it just seems like the foam backing or whatever is under the cloth is dented inwards and lost its original form...
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
The foam underneath it is not a forgiving foam and will keep that crease, it's rather stiff (so it stays in place!). There is also spray adhesive holding the material to the foam. You could try steaming just that spot (don't actually touch the surface though). A steam iron that allows you to push a button and a bunch of steam comes out is what I am referring to. Alternatively, take it to a car upholstery shop and they can do it.
Good luck!
huntergreen
Marine Corps Navy Badge
Not sure that can be fixed short of replacing the foam.
