ISO front suspension spec/informative
Hotboy
Ok guy. I need all the help I can get!?
I have a 07 nitro r/t. Can’t get lift for and the nitro world said it can’t be done. Other than the 2.5” coil Spring boosters witch I already have installed. So I’m determined to prove this wrong!
Iv found the maxtrax 3.5” maga cab lift spindles are over all 16.25”. The same as the nitro stocks!
If I install the 3.5” lift spindles, that’s a 7” bolt on lift!?
Ok now the headache begins!
Like ball joint size/taper? Hub assembly?
My question is dose any one know the size and taper of the maga cab ball joints?
Can a nitro or regular 1500 hub assembly bolt to maga cab spindles to keep a 5 lug pattern rather than the 8x6.5?
They all are three bolt hubs.
Any help with specs on topic will be greatly valuable to the world of dodge nitro owners
Steve58
