TomB 1269
- Joined
- Mar 27, 2019
- Posts
- 452
- Reaction score
- 454
- Location
- Schenectady NY
- Ram Year
- 2019 Classic
- Engine
- 5.7 Hemi
I did not read thru the whole thread but would like to throw my 2 cents in. 1st your payload is your limited factor. 2nd the dry tongue weights are helpful but only with respect to dry trailer weight, and that is to calculate the percentage of weight transferred to the ball by the trailer, i.e. Trailer with 500lb dry tongue and 4500lb dry trailer is 11% tongue weight. The % tongue weight then helps you understand what you will most likely be looking at for actual tongue weights when you multiple the % tongue weight by the GVWR for the trailer, i.e. 11% of 4865 = 535lbs of tongue weight, where 11% of 7200gvwr is 792lbs.Ok so we're looking into our first TT and we think we've narrowed it down to three. Looking for some feedback and suggestions. Before I list those here are some deets on the truck.
Tx in advance-
Now deduct those from your payload and you'd have 506lb remaining available on the one with 7200gvwr and 763lbs remaining on the one with a 4865gvwr.
Then subtract yours, the wife's, your sons weight, plus an add-ons to the truck (steps, tonnue cover, etc.) along with anything you will be carrying in the bed. Just a basic assumption, but with the 3 of you in the truck and truck connected to the 7200gvwr trailer you would have less then 100lbs of available payload left. With the 4865gvwr trailer you would most likely have 350 or less of available payload left, and still need to deduct 50 -75 lbs for steps and bed cover.
I always want the dry tongue weight and dry trailer weight along with the GVWR for any trailer I am interested in hauling as it allows me to get an estimate on what I will realy be looking at for weights.
Couple of notes:
1. Most trailers have about 1000lbs of payload (difference between dry and Gvwr)
2. Most people will utilize 80 to 90% of the trailer payload by the 2nd year with "stuff" in the trailer (food, clothes, toys, etc. etc.)
3. Most travel trailer (i.e. non-toy haulers) have a tongue weight percentage of at least 11% and less than 13.5%.
4. Toy haulers (bumper pull) have 15 to over 20% dry and are designed to be loaded in order to actually decrease the percentage of tongue weight. I.e. a properly loaded toy hauler can have a "WET" or loaded tongue weight at or just above the dry tongue weight.
5. 5Th wheels normally have a pin weight of about 25%
The last thing is when you setup brake controller and hitch understand their operations. Hitch should always be set at a height in which the trailer rides slightly nose down at the ball. Proper brake controller setting you should be able to lock up the trailer tires when using the over-ride thumb switch during setup.
Always check brake controller is properly set before each trip or re-connection of trailer to truck.
