MAP Sensor bolt STUCK - any ideas
kevaug
CT
4.7L
Hi - I was trying to replace my MAP sensor on my 2004 Ram 1500 4.7L
I cleaned out the torx recess with a wire brush & sprayed the bolt down with liquid wrench. I used a T15 torx bit with a low profile ratchet set and it fit perfectly in the limited space that there is between the bolt head and AC compressor. Needles to say I stripped the T15 torx. head. I am confused as the housing it sits in is molded plastic - I assume it is lined with a metal thread and most have corrosion.
So today I took my dremel and cut a slot for a flat blade screwdriver. It fit well. I used liquid wrench and PB Blaster. I cannot budge this tiny bolt.
The screwdriver is at a slight angle due to the mounting leg of the AC compressor.
Would it be OK to dremel out a little arch in the AC mounting leg so the screwdriver can be more head on? Or do you think I should remove the belt and then remove
the 3 AC mounting bolts and move the compressor a bit. Not sure how much wiggle room I will get with hoses still connected and oil fill tube right next to it.
Any suggestions?
Thanks
Kev
Marley
VA
That's unfortunate, those bolts require minimal Torque.
I personally prefer Kroil for stubborn bolts.
If you end up breaking the head, it's not mandatory that you use a bolt on map sensor.
I ended up using a twist on without issue even though I have 2 obvious bolt threads but I'm dealing with a 5.7.20190514_165313.jpg
K
kevaug
CT
4.7L
Thanks thats encouraging in case I snap it. I was wondering if it was really necessary since the other mounting hole doesnt have a bolt it looks like it just a post.
I initially wondered that myself because the vacuum is so great and must really suck in the MAP.
kad
Hudson Valley, NY
5.7L HEMI
I had a similar problem on a Jeep Liberty with the V6. I ended up breaking the plastic from around the bolt and then taking a pair of vice grips to it to get leverage.
-K
K
kevaug
CT
4.7L
Thanks K, thats a great idea. I will attempt some more patience today but if not this hopefully would be a solution.
K
kevaug
CT
4.7L
Any chance this bolt is lock tighted in? Can I apply a heat gun to this area or will I damage the plastic intake and plastic MAP sensor?
K
kevaug
CT
4.7L
Well I finally got it. I went out and bought a brass punch and spent 1/2 a day on the light tapping / penetrating oil routine.
My horizontal dremel cut was getting a little worn for my screwdriver so I decided to hand cut a vertical slot using a hacksaw blade.
I then grinded down a screwdriver blade to fit the hacksaw slot. I used the largest screwdriver I could to get the most leverage.
I then removed the AC condenser to give me more of a head on shot at the bolt.
That thing was so tight but eventually it snapped free. Thanks for all the great advice.
Reactions: kad
kad
Hudson Valley, NY
5.7L HEMI
Glad to hear that you got it out.
-K
