more plasti dip
chuck
Maryland
2013 True Blue Big Horn
Damn that looks amazing! Both the tips and rims, great job!
Sent from my iPhone using Tapatalk 2
quietpeen
2021 TRX
Hellcat
tips look good. I've wanted to do that for a while but never get around to it.
BlkRamRt
SoCal
HEMI 5.7
looks great are you planning on doing a lift?
MoparMulisha
New Windsor, MD
Looks sweet! Do you have plans to Niteshade your tail lights? If not I would add it and also if you do that, tint your fogs also.
Keep up the good work!
argray90
NW Burbs, IL
Looks great. I read plastidip holds on the tips, what paint you use?
mossyoak03
mossyoak03
portsmouth, va
Thanks guys
If I do a lift it'll be after the warranty is up an it's paid off.
I want to do them but not dead set on them just yet
I didn't want to chance it. I got the high temp. paint from lowes. So far it's holding up great has only been 2 days so we wil see
res1551cue
Scott AFB, IL
Thanks guys
For the tips, did you have to remove the bumper to paint them?
JPDud2
tips
Does the plasti-dip stay on your tips even at high temps??
mossyoak03
mossyoak03
portsmouth, va
Did you sand the tips before putting the primer on? Would you reccommend using Rustoleum paint for like BBQ Grills on the tips?
I didn't sand them I cleaned them with alcohol real good. I used the rustoleum for engines it's 2000 degree paint but I'm sure the one for BBQ grills will work too.
Chewy
Bettendorf IA
V8
Looks great!
I WOULD recommend you sand the tips to give them a key for the paint to hang onto.
68Cudaconvert
