Mustang GTD,check out the price on this toy.
2025 Ford Mustang GTD First Test: It’s Not Just About the Numbers​
It’s an insanely priced Mustang that weighs more than two tons. It’s also one of the best cars we’ve ever driven.
Jonny LiebermanWriterWilliam WalkerPhotographerJun 04, 2026
Pros​
  • Crazy cool suspension
  • Massive, extremely grippy tires
  • Astonishing braking performance
Cons​
  • Very heavy
  • Very wide
  • Paltry mpg, tiny range
Every so often, a car comes along that scrambles conventional wisdom. Remember when EVs were nothing more than glorified golf carts? Boom, meet the Tesla Model S, a car so good it revolutionized the automotive industry. Porsches are great track toys, but when it comes to drag racing, leave that to the hot rodders, but have you met a 911 Turbo S in the last two decades? British cars are fantastically styled, beautifully appointed, but lousy in terms of reliability. OK, that last one hasn’t changed, but cars have only been around for 140 years. Maybe one day!
Looking over our First Test chart of the new Ford Mustang GTD, one number would seem to seal the uber-pony car’s fate before another word gets typed: weight. On the MotorTrend scales, we saw an astonishing 4,411 pounds. That’s basically what a Kia Telluride weighs. Here’s where we’re going to need you to read the opening sentence again.
GTD Nickel Tour for the Uninitiated​
Assuming you’re here because you’re dying to know what a $438,200 (as tested) Mustang is all about, we’ll keep the preamble to a minimum. You can read all about the heavily modified ’Stang right here and here. However, if this is the first you’re hearing of a GTD, here’s a quick nickel tour. Ford sends Mustang body-in-whites northeast to Canada from Flat Rock, Michigan, to Multimatic in Markham, Ontario. From there, the Multimatic team removes the front and rear ends, installing carbon-fiber and aluminum parts up front and a tubular steel subframe out back. Torsional stiffness goes through the roof, and its roof is made from carbon fiber, as is every other body panel, including the door skins and the trunklid. This Mustang is massively widened, as well, swelling by over 6.0 inches to 81.7 inches. To contextualize that for you, the current Range Rover is 80.6 inches wide. It’s so wide that the side mirrors only stick out 0.2 inch past the bodywork. If it were a truck, it would need clearance lights.
The GTD’s mighty engine is a hopped-up version of Ford’s Predator 5.2-liter supercharged V-8 that in this application is good for 815 horsepower and 664 lb-ft of torque. And yes, children, there was a time not that long ago when 815 ponies was an eye-watering amount of power. Packaged low in its tubular rear subframe sits an excellent Tremec dual-clutch transaxle—the same one found in the C8 Chevy Corvette.
Multimatic supplies the hydraulically actuated spool-valve dampers front and rear. The rear dampers are especially trick, for not only are they horizontally mounted and pushrod actuated, but there’s also a piece of plexiglass where the rear seat used to live that allows you to look right at them. Be sure to tilt your rearview mirror down and watch ’em work. The lightweight magnesium rims are wrapped in sticky, freakishly large (325 front, 345 rear) Michelin Pilot Sport Cup 2 RS rubber. GTD spec, of course.
It all adds up to 4,411 pounds of fun. That’s a supremely heavy Mustang.
Astonished By How Magical It is​
After just three turns on the racetrack, I was quite shocked to realize that my initial thought was, “This thing drives small.” One corner later I thought, “This is one of the best cars I’ve ever driven.” After three laps, I had the same thought in my head. Ford and Multimatic had sent a team of techs/minders out to the track with the GTD, and I walked over and began expressing my astonishment and admiration to them. Thinking back over my 21-year career, I can’t recall ever doing that with any other car.
The next day, up on some blistering canyon roads above Palm Springs, I was driving a 1,250-hp Czinger 21C alien attack vessel with a $2.5 million price tag, and I was pushing it hard. Yet as quick as I was going, every time I clocked the mirrors, there was our road test editor, Eric Tingwall, in the GTD on me like stink on French cheese. Well, I thought to myself: “I’m fat and old. It’s been a pretty good run, everything peaks, it’s all downhill from here.” So imagine my surprise when later that day after we swapped cars, I found myself steering with just one hand in the GTD and sitting on the Czinger’s bumper, while ol’ Tingwall struggled to keep the hypercar in its lane.
How do we account for the Mustang GTD driving so well? Tingwall thinks it’s the trick suspension. “There’s none of the float and bounce that’s characteristic of a regular Mustang,” he noted. “The nose dives into turns with perfect precision. The suspension is busy but not necessarily harsh, with firm damping and reasonable spring rates.” While the crazy, high-tech dampers are no doubt a large part of the answer, let’s talk contact patch. One of the reasons the Bugatti Veyron became infamous was because of its 365-width rear tires. The fronts? A still very wide 265mm. Well, the GTD’s freakishly large bespoke Pirellis put 6 percent more rubber to the road overall than a dang Veyron. Man. Just magic. You know what? The whole thing is magic.
The Numbers Need Some Context​
The sprint to 60 mph happens in 2.7 seconds. Some context. Any RWD vehicle that gets it done in less than 3.0 seconds is seriously quick. However, ye olde regular Corvette (495 hp) got there in 2.8 seconds, and the current Z06 beats it with a 2.6-second scramble. The 1,064-hp Corvette ZR1 only shaves that time down by another tenth, taking 2.5 seconds. The 1,250-hp hybrid AWD ZR1X? In 2.1 seconds. Also, what’s a “base” Corvette going to do when the upcoming 2027 model lands packing Chevy’s new LS6 6.7-liter V-8? Probably at least tie the $438K Mustang to 60 mph, if not whoop it outright.
Still, 2.7 seconds is mighty quick, a time that beats a 5,406-pound hybrid AWD Bentley Continental GT Speed (2.8 seconds) that can (probably) be optioned up to the same price. Also, the slightly detuned Shelby GT500 with the same engine needs 3.7 seconds to hit 60 mph, meaning the GTD bests it by a full second, while the 2017 Ford GT needs 3.0 seconds to hit 60 mph. So there’s your context. Moving on.
W
In the quarter mile, horsepower proves more important than torque, and the Mustang GTD turns in an impressive 10.5-second sprint at 134.9 mph. Big numbers. Here comes some more context. The regular C8 Corvette needs 11.1 seconds at 123.2 mph, whereas the 670 hp Z06 takes 10.6 seconds at 129.5 mph. Now’s a good time to point out that the GTD weighs about 900 pounds more than the Stingray and around 800 pounds more than the Z06. Now, the big dog Corvettes? The 1,064-hp ZR1 breaks into the nines, running the quarter in 9.9 seconds at 144.2 mph. The ZR1X drops it down to an impressive 9.2 seconds at a big boy 153.3 mph. Back to the Fords, the GT500 was a full second behind the GTD, needing 11.5 seconds at 129.6 mph, whereas the Ford GT ran it in 10.8 seconds at 130.5 mph. Funny enough, that ties the Bentley, which also runs 10.8 seconds at 130.7 mph All that said, the 815-hp Ford GTD is damn quick, but bottom line, you can go quicker for less cash.
When it comes to braking prowess, the 2.2-ton curb weight should let us know that the GTD ain’t going to stop so well. Emphasis on should. For you see, friends, the mega Mustang whoas itself down from 60 mph in just 89 feet. That’s remarkable. That’s incredible. That’s almost unbelievable. Pick a superlative. Wow. In terms of stopping power, the GTD beats every single car mentioned above. The best of the rest would be the 3,354-pound Ford GT, which stopped in an also excellent 95 feet from 60 mph. That 89-foot number ties it with the Dodge Viper ACR (track setup; the street ACR needed only 87 feet) for seventh best all time. Perhaps this should come as no surprise, as the best car MotorTrend has ever tested in terms of braking from 60 mph is the 4,028-pound Ford Mustang Dark Horse, which did the deed in just 86 feet.
As for our signature figure-eight handling test, the GTD doesn’t disappoint, completing our 1,600-foot course in just 22.6 seconds with a max lateral acceleration of 1.13 g. As I’ve long said, anything under 23 seconds is a supercar. Case in point, the GT500 does it in a pretty decent 24.1 seconds. That said, 1.5 seconds over 1,600 feet is essentially night and day. As for the Chevy gang, the C8 Stingray runs a 23.3, the Z06 a 22.3, the ZR1 does a 21.6, and the ZR1X actually goes slower than the ZR1, needing 21.9 seconds. The Ford GT? 22.7 seconds. To me, this is insane, as I remember being blown away by how nimble and great to drive on a track the original third-generation GT was. Props to Ford (and Multimatic, who also helped build the GT) for getting a Mustang to beat its mid-engine supercar in a handling exercise. Oh, and the Bentley? 24.5 seconds, which all things considered is just fine.
Conclusion: If you love driving and have the money, the Ford Mustang GTD is an absolute must buy. My highest recommendation.
2025 Ford Mustang GTD Specifications
BASE PRICE$327,960
PRICE AS TESTED$438,200 (MT est)
VEHICLE LAYOUTFront-engine, RWD, 2-pass, 2-door internal combustion coupe
POWERTRAIN5.2L supercharged port-injected DOHC 32-valve V-8
POWER815 hp @ 7,400 rpm
TORQUE664 lb-ft @ 4,800 rpm
TRANSMISSION8-speed dual-clutch automatic
CURB WEIGHT (F/R DIST)4,411 lb (51/49%)
WHEELBASE107.1 in
LENGTH x WIDTH x HEIGHT193.6 x 81.7 x 54.0–55.5 in
TIRESMichelin Pilot Sport Cup 2 R FP
F: 325/30ZR20 (102Y)
R: 345/30ZR20 (106Y)
EPA FUEL ECONOMY,
CITY/HWY/COMBINED
10/17/12 mpg
EPA RANGE192 mi
ON SALENow
MotorTrend Test Results
0-60 MPH2.7 sec
QUARTER MILE10.5 sec @ 134.9 mph
BRAKING, 60-0 MPH89 ft
LATERAL ACCELERATION1.13 g
FIGURE-EIGHT LAP22.6 sec @ 0.97 g (avg)
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
This is just laughable. Like to see one broke down on the shoulder of the road or out of gas. And can you get it with zero down and zero % interest?
And I'll bet this not even a blip on the financial radar for anyone
dropping $438,000 on a car. ;)
Nick@GotExhaust
Supporting Vendor
SC
Been watching a decent bit of content on the GTD and the ZR1X. The GTD is very impressive when used for what it is built for. Not going to get into whether its worth the price or not even though it will outperform most vehicles on a road course in its price range. Im going to enjoy the back and forth competition with the GTD and ZR1X will continue to have at the ring.
MrBonez
Central Alabama
2008 Laramie Quad Cab
Based on TV ads if you were to go with Liberty you would only pay for what you need :33: :evillol:
What's needed being the subjective here - And I guess Liberty is "At Liberty" to decide how much that is themselves, placing you in "Good Hands"...... Or so they'd say.
Talk about some "Mayhem" to your wallet...... :anitoof:
seems fishy
Ontario
For that price it should at least have a radio?
I'll bet if that was brought to your average Ford Dealer for warranty repairs nobody would even know where to start .Likely,they will not give you a GTD loaner car either.
I had a 2006 Roush Stage 3 Mustang I bought new in 2006,and the Dealer had it longer than I did because it was in for repairs weekly .It was in limp mode most of the time....Companies go all out on advertising their best achievements,but they are in no way bullet proof and fixing them is not a breeze (say in comparison to a 6cylinder, 1963 Pontiac Strato Chief,as an example)...
I worked at a Ford Dealership and watched the lead Mechanic
undo a set of bolts on dry sump,
2005 FORD GT( not Mustang),to change the oil [ It was an honour to work on that car]
and ,those weren't even the right bolts.ALL the oil was out of that car ,and on the floor,faster than he could say ...
OH S**T...
Imagine crashing that GTD on a race track(that is where it belongs),and eating the loss,if you survived)
Ram Too
NE
Diesel
Congrats to Ford! Amazing car! The weight is something, though they have figured out how to negate it.
There are lots of people out there with lots of money. I’ll bet the sell out every one they build. Glad to see the bar continues to get raised.
PS If they could figure out how to build a decent truck they’d be on to something.
Buddy
Ottawa, Ontario - cool town
Some amazing cars today witjout question. Prices are just insane, but there will be people with lots of cash who don't think twice.
Even a Mustang Darkhorse is pricey, and a Darkhorse SC (795hp/660tq) starts at $144 CDN. Mark enough of the option boxes and your well over $200.
To think back in the day Chevy released the 375hp ZR-1 and Dodge the 400hp Viper both big drals at the time. A Hemi Ram is 395hp. Yes time has passed, but we have race cars on the road anyone with $$ can buy, and race car prices too, lol.
