G. Mcpherson
- Jan 14, 2017
- 850
- 424
- Location
- Vancouver, Wa.
- 2023 Ram 2500 CC SB Tradesman
- 6.7 Cummins
This is the issue I would say. Turn around for the fix or replacement from PowerTeq is fast. Usually 2 days.That's definitely not an adaptives learning issue. My bet is a bad PCM. It happens. I had to have the first PCM I got from Diablosport replaced. However I had to go to their parent company PowerTeq to get it. DS was useless as far as support. I would've suggested reloading a tune. You did that, and the problem didn't go away. And the OEM PCM is fine. That would suggest a bad PCM. Sure wouldn't run the engine like that.
Good luck!
wink
