R&R Turbo Actuator
ajv00303
If you remove the Turbo Actuator to check the movement of the Turbo lever, and you reinstall the same actuator, does it need to be re-calibrated?
Jawsopter
Canada
CUMMINS
You should re-calibrate just in case... alfaobd can re-calibrate...
southalum
