RainMaker
I have a new to me 2003 Ram 1500 Quad Cab 4x4 with tow package. I'm getting the left turn signal and brake light and parking lights at the 4 way connector but no right turn signal or brake light. I can hear the relay/flasher working under the fuses at the fuse box and it will stop when I pull the fuse to the right side.
Haven't been able to trace the wire all the way from the 4 way connector to fuse box but have spot checked up to about halfway to the front of the truck from the 4 way.
Could the relay be working and still not sending power out of the fuse box? If so, has anyone had any luck using an aftermarket powered trailer light converter/adapter and if so any brand and model recommendations?
Thanks in advance for any help.
