RPM hangs and Cuts out
R/T_Fire
Pleasant Grove
Have two issues I've noticed and trying to figure out. I have listened to sound clips of other R/T's and they seem to drop rpm pretty quick with no load. Mine just hangs there and slowly comes back down if I rev to 3-4k it takes like 5-7 seconds to come back to idle, may be normal with these trucks but just seems odd to me.
Issue two is around a hard corner or in a curve and excelerating out of it on a 90 degree turn from one street to another, it will cut out, stay running but throttle has no response.. just seems odd.. also kinda feels like the pedals are loose...
Ramsfan78
St. Peters, Missouri
HEMI 5.7
Do you have a tuner and do you have a HF tune? The reason I ask is because my 2010 1500 does this exact same thing. It only does it when I have the tune installed. When it is running the stock tune it does not do it.
R/T_Fire
R/T_Fire
Pleasant Grove
No tune that I know of unless it was loaded and left on there when traded in.
SSGart
