SOLD Factory Kicker SubWoofer Phoenix AZ
Status
Not open for further replies.
spdglez78
US
Hello,
I have a factory sub for sale.
Fits crew and quad cabs.
The factory amp and harness needs to purchased separately or you can use an aftermarket 1ohm amp
Went for a stealth box instead.
I will entertain shipping.
Be aware, as it is heavy and bulky, it will be expensive.
To ship one hour away within the phoenix area will run roughly $40.
To go to Mid to East Coast it is in the 90-100 range.
Sent from my SM-G970U using Tapatalk
MADDOG
Living in a Firepit
Rules require that a price be posted on For Sale ads.
kp4243
NC
Crew cab or Quad?
spdglez78
spdglez78
US
Sorry Guys $100.
spdglez78
spdglez78
US
I had it in a quad cab.
jawzs2
Air Force
South Jersey
Is the amp and wiring included?
spdglez78
spdglez78
US
Just the sub.
spdglez78
spdglez78
US
Yes i will ship.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Thats a deal!!!
If anyone needs harness for PNP, let me know.
Will require the BTL amp if someone wants a true PNP.
Fits quad and crew.
monettejb
2018 Hydro Blue Edition Ram 1500
Greenville, NC
Thats a deal!!!
Fits quad and crew.
Forgive me as I’m normally knowledgeable and research but how much is harness and what is a BTL amp? I have factory 8.4 non premium system. What would it cost me to get this working as I’m highly interested
spdglez78
spdglez78
US
I used it in a non premium system and wired it directly to an aftermarket amp.
Graygoose
Oklahoma
Convert, for now.
small
It comes factory with a T-harnesss to plug right into the 8.4 radio. Then there's a 200watt amp that comes with it.
I have the harness, if you can find the small 200w amp, its all literally plug and play, install in about 30 minutes.
You see the small amp here.
https://www.sonicelectronix.com/ite...MIsNHR96e87gIVEvDACh0yKALwEAAYAiAAEgLSNPD_BwE
spdglez78
spdglez78
US
Yes, factory or aftermarket amp is all the same.
Graygoose
Oklahoma
Convert, for now.
small
well an aftermarket amp isn't the same, exactly.
The 200 BTL amp has a low current draw, does max power at 1 ohm, and has a built in compressor to pull down power if its seeing distortion from an overmaxed volume knob. The front VSS amps does the same. Plus the harness has everything, plug and play, the other you may need an LOC, power, ground, remote, etc. Some of the VSS BTL amps work with stop/start
But someone could get an amp that will do 200-250 watts at 1 ohm.
Status
Glowz
