? What?These lights have internal motors that control the focus of the beam.
What he is trying to say is that you can buy brand new OEM headlights for cheaper.You can get cheap ones for a lot less yes. These are not cheap lights. They are over $1000 each from dodge. These are less than half price for 6 month old lights. A hell of a deal.
Tried a few different styles but ended up going back to stock. Had the dealer replace some old ones I had under warranty with factory ones so I ended up with an extra set. Never found anything brighter. These are great lights. i was going to keep them for spares but by the time I would need them I will probably have a new ride.
When he says internal motors he's referring to a solenoid that pulls the low beam cutoff shield down for a "full beam" or "high beam". That's standard on all projector sport headlights as its a bi-halogen projector. Not anything special. Same thing goes for bixenon HId projectors... Same thing but with an HID bulb. The "bi" part means it's part low beam and part high beam, so the one light is effectively both and more compact. A lot of OEMs use dedicated low beam projectors and dedicated high beam projectors. That way they don't have to worry about solenoids failing or getting stuck in the up or down position. Personally I like the bi function.
Glws
That's for aftermarket which are not nearly as good or as bright. You won't find OEM headlights at that price.
