suggestions?
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
tuner is one, if not the best bang for the buck mod.
E
eryk
5.9l 360
so does this seem like a solid list? or should i still kick the intake?
i know its going a little over budget but if this is a good setup then would wait and save more for the project...
SCT XCalibrator 2 Programmer $195.00
RDP Store - SCT Dodge / Chrysler DCX XCalibrator 2 Handheld Programmer
Harland Sharp 1.7 Rockers $295.95
Harland Sharp S7307 - Harland Sharp Pedestal Mount Bolt-On Series Rocker Arms - Overview - SummitRacing.com
Modified O.E.M. V8 Throttle Body $165.00
Hughes Engines
ACCEL DISTRIBUTOR ROTOR $8.95
Hughes Engines
ACCEL DISTRIBUTOR CAP $14.95
Hughes Engines
MSD wires $79.95
Hughes Engines
180º POWERSTAT $7.95
Hughes Engines
MSD ignition coil $46.95
Hughes Engines
ADAPTER HARNESS MAGNUM COIL $23.95
Hughes Engines
FI AirGap Kit $599.99
Hughes Engines
PaceSetter Performance $233.95
PaceSetter Performance 70-1315 - PaceSetter Headers - Overview - SummitRacing.com
Flowmaster Super 10 $69.99
Flowmaster 8425152 - Flowmaster Super 10 Series Mufflers - Overview - SummitRacing.com
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Still seems like a good list in my book. Check with our vendors and see if they can beat the prices you got.
The intake could go either way. Of and please say you arent going to use the factory air hat and filter.
Sent from my DROID RAZR using Tapatalk 2
E
eryk
5.9l 360
haha nope i have a k&n cai
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Ok good. You had me a little worried for a minute. lol All that work and parts then choke it with a factory airbox. lmao
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
get you some stage 8 locking header bolts and good remflex header gaskets. that way you are not having leak issues with the headers. i will never put a set of headers on without both. they are the best. they make a header install worry free.
the codes
Houston, Tx
Magnum 5.2
I am on the same page as these guys :)
I have the Hughes intake and I would also recommend the msd coil I also have. and the Fastman tb is a must! one of the greatest mods so far for me.
and with the intake, expect to see a loss in the bottom end. the top end is where it really helps. I went ahead and got the intake because of my "future" plans for the engine, regardless it's a gold product IMO though. but if your not going to dive into the engine I think the kegger is your most bang for your buck.
I would say kegger and get the sct tuner from Sean and a set of 1:7 rockers. if you look at some of Sean's dyno graphs those are your two big power mods for
the best buck. I myself wish I had the rockers already.
you veterans feel free to comment and correct anything I might have fumbled!
otherwise nice list!
Tapatalk Addict
Okiespaniel
Work, Shop, Computer
magnum, 5.9
I didn't this listed anywhere, but if you check your timing chain and it's got slack, you might want to redo it as well.
Also new hoses since you have to remove all of them...:)
E
eryk
5.9l 360
alright so ive tackled a good part of this list and got a little side tracked but this is what im hoping to do and slap it all behind an nv4500 conversion. but my question is will all these parts work and work with my current mods? any help is much appreciated.
SCT XCalibrator 2 Programmer $265.00
SCT
Harland Sharp 1.7 Rockers $349.95
Harland Sharp Original Roller Rockers S70037 - SummitRacing.com
Mopar Performance Cast Aluminum Valve Covers $191.95
Mopar Performance Cast Aluminum Valve Covers P5007617 - SummitRacing.com
Edelbrock Cylinder Head Gaskets Sets 7371 $99.95
2001 DODGE RAM 2500 Edelbrock Cylinder Head Gaskets Sets 7371 - SummitRacing.com
Fastman Throttle Body $265
5.2L - 5.9L V8 Throttle Bodies - The Fastman
GMB High Performance Water Pumps $109.95
2001 DODGE RAM 2500 GMB High Performance Water Pumps 120-3041P - SummitRacing.com
Flex-a-lite Heavy Duty Fluid Coolers $105.95
2001 DODGE RAM 2500 Flex-a-lite Heavy Duty Fluid Coolers 45261 - SummitRacing.com
joshhhh
