tires for leveled ram 1500
30stones
Duncansville Pa
I just ordered some bilstein 5100's for my 08 quad cad 4x4. My next step is tires. I'm thinking of running 305/55/20 on my stock rims. I was just seeing if anyone had any pictures of leveled rams with the stock 20's with a similar size tire. Not sure if I'll be running 2.1 or 2.8 any suggestions would be great thanks!
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
With 305 wide tires on stock rims you may need wheel spacers. 285 is typically the widest you can go to guarantee no rubbing but lots of guys get away with 295's as well. Personally I'd run a larger diameter on a leveled truck. You'd be better off with a 295/60/20.
30stones
30stones
Duncansville Pa
Thanks guys I appreciate it! If I would get the spacers the wheels will probably stick out past the fender a good bit huh?
brandonjansen
Not if you only get 10mm hubcentric spacers from Motorsport Tech. That's all you'll need clearance wise.
30stones
30stones
Duncansville Pa
If I decide to run the 305's I'll need to get the spacers if I rub the 295's I'll be ok without them? Anyone have any pics? I've found a couple on here but they're on 35's.
I run a 295/65/20 on my 2010 with stock wheels, only rubs at full lock
30stones
30stones
Duncansville Pa
Where do you guys buy your tires? I've looked and can hardly find anything in a 295/60/20
Steve58
