TPMS Issue, not typical
SlightlyTweaked
Sullivan County NY
5.7 HEMI VVT
Where is the "receiving" sensor located for the front wheels of a 2014 Ram 2500? My issue started a month ago, the TPMS light will come on and my EVIC will flash BOTH font tire pressures (yes they are both over the 60lb threshold). The pressure is good and both start flashing together and then go off after a little while , then start over again a day or so later. First I thought it might be caused by the spare tire, but that is ok on air. So my next assumption is the sensor that receives the pressures from the front 2 tires. Anyone know where that sensor is located??
:banghead:
jpsfj60
2016 2500 HD
Each wheel has one held in by a set screw I believe. Have your dealer check
them.
SlightlyTweaked
SlightlyTweaked
Sullivan County NY
5.7 HEMI VVT
If you're referring to the sensors inside the tires it's not those. It's whatever module those sensors send their info to, that's the one I need to locate.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
I would assume the rear has a similar setup. If the receivers are the same part number, you could swap front to rear and see if the problem travels to the rear.
