What size lift do I have?
Johnn123
Ontario
One other thing to consider about the ride is your tire pressure.
My idiot brother-in-law has his tires inflated to 80psi all the time because that is what it says on the side wall for max psi. He doesn't believe me when I told him that was the reason his tires are wearing so badly in the center.
That's another good point, what tire pressure are you running OP?
JoshuaDeBoard
JoshuaDeBoard
Indiana
5.9 Magnum
i'd say 30-35 usually.I was thinking the 33's because well for one,their cheaper, two,less wear on front end, and third was just a thought that if I can rip through mud easily with 35's and bark em down the road on accident with 35's, then 33's would just add more getty up to it all...right? one question too is i am running 1900rpms going 55 with these 35's......if i switch to 33's will they climb my rpms to much and make me of a frequent visitor at the gas pump?? opinions?
BBartow
New Port Richey, Florida
5.9L Magnum
3rd gear @ 55 with 35s is 1874rpm
3rd gear @ 55 with 33s is 1988rpm
Fatboy1989
