Alex
- Sep 25, 2012
- 608
- 96
- Location
- Weyburn, SK, Canada
- 2015 Mustang GT
- 5.0
I'm looking at getting to the audio in the truck now, looking at the 2 -12" vented foxbox, and comparing their specs to the sub I'm looking at, it looks like it might fit, but if it does, it'll be a tight squeeze. Sub is a RE Audio SXX line 12" DVC 4 ohm.
I'm hoping it will fit, I love these subs, have a set of the SEX line in my car, and they are massively loud and sound great while they're at it
Sub specs from RE Audio site
12"
Mounting Depth - 6.9 inch
Mounting Hole Diameter - 11.2 inch
Overall Diameter - 12.5 inch
Bolt Hole Circle - 11.75 inch
Motor Width - 7.3 inch
Motor Depth - 3.44 inch
Basket Depth - 3.46 inch
Displacement - 0.16 cu. ft.
Weight - 24.5 lbs.
Foxobx specs
2-12" VENTED SUB BOX
AIR VOLUME: 1.55 CUBIC FEET PER SIDE
DIVIDED: YES
PORT/VENT TUNE FREQUENCY: 35 Hz
MAX FRAME SIZE: 13"
MOUNTING HOLE SIZE: 11.125"
MOUNTING DEPTH: 7.25" WITH A 6.5" DIAMETER MAGNET
I'm assuming "Motor width" is the magnet size, which is why I'm not 100% sure this will work. They mention that they slightly lowballed their size specs, which is giving me hope
Here's links to the sub
http://www.sonicelectronix.com/item_27318_RE-Audio-SXX12D4.html
http://www.reaudio.com/woofers.php
Any help is very much appreciated, time to show this truck some real bass haha
12"
Weight - 24.5 lbs.
Foxobx specs
DIVIDED: YES
MAX FRAME SIZE: 13"
