Worth replacing all Blend Doors on 4th Gen?
Ken226
Washington State
I'm still new to AlfaOBD and only done a couple config changes so far. Will this Calibration Test produce a pass/fail type report? Thanks.
I'm not sure. i've never had any reason to run the test on my truck.
But if you do it, report back and i'll know going forward. :)
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
How do you do the calibration procedure..i have a 2017 and i have very little heat..did heater core flush..changed thermostat and new antifreeze..i can see the acuator motor turning the blend door but it could be broke inside..but id like to yry the calibration 1st
There are youtube videos out there. Watched them, but have not personally done it. You hit some control buttons in a certain sequence.
Also, if you have AlfaOBD, you can re-calibrate and test a bunch of functions using the program with an OBD dongle like the OBDLink MX+.
bigbrat
Canada
I've watched videos but none seem to work for me
H
_happy_
Brooklyn, NY
I'm assuming the manual calibration wont work with your year? I know it works with mine (2012)
bigbrat
Canada
jackr815
Belvidere IL
Complete new HVAC box available from Dodge, less than $400. Does not include heater core or evap.
JohnLoves2Ski
Northern Hemisphere
Press and hold the recirc button for 10 seconds, then release the button and press it again, hold until the light starts flashing. When it stops flashing, it's done.
No members online now.
mvm2
