Ken226
- Joined
- Mar 12, 2017
- Posts
- 2,308
- Reaction score
- 5,984
- Location
- Washington State
- Ram Year
- 2013
- Engine
- Hemi
I'm still new to AlfaOBD and only done a couple config changes so far. Will this Calibration Test produce a pass/fail type report? Thanks.With AlfaOBD or a scan tool, connect to the climate control module and run the actuator calibration test:
There are youtube videos out there. Watched them, but have not personally done it. You hit some control buttons in a certain sequence.How do you do the calibration procedure..i have a 2017 and i have very little heat..did heater core flush..changed thermostat and new antifreeze..i can see the acuator motor turning the blend door but it could be broke inside..but id like to yry the calibration 1st
I've watched videos but none seem to work for meThere are youtube videos out there. Watched them, but have not personally done it. You hit some control buttons in a certain sequence.
Also, if you have AlfaOBD, you can re-calibrate and test a bunch of functions using the program with an OBD dongle like the OBDLink MX+.
No that did not work for meI'm assuming the manual calibration wont work with your year? I know it works with mine (2012)
2010 Dodge Ram No Heat? How To Calibrate The A/C Heat Blend Door Temp Actuator Location
#car #dodge #howto #automotive #diy #youtube #cars #new #subscribe #like #fyp #mopar #shorts 2010 Dodge Ram No Heat? How To Calibrate The A/C Heat Door Blend...www.youtube.com
Press and hold the recirc button for 10 seconds, then release the button and press it again, hold until the light starts flashing. When it stops flashing, it's done.How do you do the calibration procedure..i have a 2017 and i have very little heat..did heater core flush..changed thermostat and new antifreeze..i can see the acuator motor turning the blend door but it could be broke inside..but id like to yry the calibration 1st
