I'm on my 4th water pump/thermostat in the 4 years I've owned mine. Many people report having issues with new water pump replacements giving out after only a few months and thermostats not working out of the box, yours could very well be "new" and still be going bad.Did your thermostat look bad? Mine looks new, as does the water pump. Only owned the truck few months.
Yours is different. You seem to have a clogged heater core, not a thermostat issue. You didn't mention though... do you only have heat on the passenger side or no heat at all? Passenger side only means partially blocked. No heat at all may mean completely blocked.im having the same issue no heat drastic temp drops but i have a 6.7 cummins and i tried 2 new thermostat should i try another?
