Alpha obd
jsmith96
Wisconsin
Hello I am new to the Forum and I'm not certain where to post. I recently turned off the constant headlights on my 2019 Ram sport (canadian model) using Alpha obd. This truck is currently in the United States so this option is not necessary. I'm wondering if anyone has any experience with changing the country code? Will this open up more options? Thanks.
Dean2
Near Edmonton
If it is still on warranty do NOT change the country code. In addition, daytime running lights are proven safety feature that costs ZERO to run. I would never turn mine off, and most of the time I run with all lights on. You are far more visible than running dark.
J
jsmith96
Wisconsin
It's not under warranty. I use the daytime running lights All the time so that I am more visible . I changed it so the headlights can be turned off when the truck is parked and the engine is running. In the Canadian model trucks the headlights are on all the time when the engine is running. Even when in park.
Dean2
Near Edmonton
If you apply the emergency brake only the daytime running lights, or eyebrows as many call them, stay lit but your method works too. My pickup is still on warranty so have not tried changing Country code from Canada to the States..
J
jsmith96
Wisconsin
Yeah I noticed when using the park brake it would shut the low beams off. But it left the signature Lighting on. Now if I turn my headlamp switch to the off position everything is off.
