Yes, I did have to make mounts for it, it's working well.Was that a lot of wiring to get that to work?
Did you mount the AC fan in front of the radiator?
This is a interesting setup.
What did you do with the blade and rotation of the factory A/C fan if you mounted it in front of the rad.It's a puller fan,not a pusher fan,so unless you did something with the angle of the blades or the direction of the motor,your great idea is going to be fighting each other,as the A/C fan mounted in front,is going to be pulling air from the engine bay,while the other fan will be trying to pull air through the rad from the front. Looks to me like you kept the V6 fan behind the rad,which means you must have mounted the factory A/C fan in front of the rad,which is back asswards to the direction it's supposed to beThe AC fan is on the PCM and comes on when I turn the AC on and when the heat reaches 220F. The second new eFan I installed comes on at 195F by using the Flex-a-Lite 31174 variable temperature controller with Probe style QuickStart this was very easy to install the only hard part was making the mounts for the AC fan.View attachment 469094View attachment 469095
Haha well, you know it all dude. No they both go the same direction and they work well keeps everything cool it was a 110 out and I had the air conditioning on and doing 100 km hr with my trailer.What did you do with the blade and rotation of the factory A/C fan if you mounted it in front of the rad.It's a puller fan,not a pusher fan,so unless you did something with the angle of the blades or the direction of the motor,your great idea is going to be fighting each other,as the A/C fan mounted in front,is going to be pulling air from the engine bay,while the other fan will be trying to pull air through the rad from the front. Looks to me like you kept the V6 fan behind the rad,which means you must have mounted the factory A/C fan in front of the rad,which is back asswards to the direction it's supposed to be
You can say haha all you want,but unless you changed the blade angles and the direction of rotation,you're idea is wacked,one fan will be fighting the other fan.This kind of goes along with everything else you appear to think you know,lol. Did you ever figure out how the cam lobes are oiled,lol.Haha well, you know it all dude. No they both go the same direction and they work well keeps everything cool it was a 110 out and I had the air conditioning on and doing 100 km hr with my trailer.
If he mounted the fan as a pusher possibly. He would have to post a better picture of the actual fan mounted. Either way the blades are not designed as pushers so the actual “push” won’t be all that great. And if it’s not sealed to the condenser than it’s useless because it’s only just blowing air at the condenser and not through it.You can say haha all you want,but unless you changed the blade angles and the direction of rotation,you're idea is wacked,one fan will be fighting the other fan.This kind of goes along with everything else you appear to think you know,lol. Did you ever figure out how the cam lobes are oiled,lol.
For anybody who thinks he's got a good idea,i'll let you know,he doesn't,as he needs to research fan blade angles and fan rotation. He's running a puller fan on both the front of the rad,and on the rear of the rad,doesn't matter what he thinks
I highly doubt he changed the blade angles Khris. Just reversing the fans direction won't turn it into a pusher fan,the blade angles would also need to be changed.If he mounted the fan as a pusher possibly. He would have to post a better picture of the actual fan mounted. Either way the blades are not designed as pushers so the actual “push” won’t be all that great. And if it’s not sealed to the condenser than it’s useless because it’s only just blowing air at the condenser and not through it.
hence why I said it wouldn’t work properly since the blades are not designed for that. If it was a proper pusher that would be different. I debated on buying a proper pusher fan and installing it but I don’t have a reason to do so since I’ve had 0 issues cooling and my ac works great.I highly doubt he changed the blade angles Khris. Just reversing the fans direction won't turn it into a pusher fan,the blade angles would also need to be changed.
You got to be a Yankee for sure.You can say haha all you want,but unless you changed the blade angles and the direction of rotation,you're idea is wacked,one fan will be fighting the other fan.This kind of goes along with everything else you appear to think you know,lol. Did you ever figure out how the cam lobes are oiled,lol.
Well for one. If you are going to insult 2 different people make sure you use your insults for the right one. And second. If you would post a better picture of the fan would be great so we could actually see how you have it mounted otherwise it’s just speculation. Now if you want to continue with the insults your posts will be reported because this is not a place for that. Otherwise have a great day.You got to be the stupidest guy on this Forum you're the
'wild one" all right wild and stupid.
Have fun with your extra 120hp you got… can you just post a picture of your fan? Or is that to hard for you? I’m sorry that your feelings are hurt because people questioned something you did and asked for pictures of it. I went ahead and reported your rude comments. hope you have fun up north. By the way I do know how airflow works and if it’s not done properly then it doesn’t work as well. Also 2 electric fans draw a lot of wattage which will load up your alternator which then uses more horsepower to maintain your electrical system.Good for you and your AC, you unmistakably don’t know anything about airflow from what I can tell, where do you think the air goes on the bull fan that it bulls in up your *** I assume, you’re probably one of does guys that promote's Diablo. I’m going to hook up to my pike trailer and go out for a ride in the woods way up north have fun, know it all.
Like i told you before bud,please take the Canada out of your avatar,you're an embarrassment to the rest of us Canucks.Like Khris says,enjoy your trip up north,and don't antagonize the bears ,like you do the guys on here,as they might not treat you as well as we do,lol.Good for you and your AC, you unmistakably don’t know anything about airflow from what I can tell, where do you think the air goes on the bull fan that it bulls in up your *** I assume, you’re probably one of does guys that promote's Diablo. I’m going to hook up to my pike trailer and go out for a ride in the woods way up north have fun, know it all.
Honestly I would take it off and go for a spin. I didn't really notice much difference with it on or off and because I tow a camper several times a year, I just left mine on....So after reading all this, I can just remove the mechanical fan on my 2018 and be ok? Not looking to drag race or anything.
You can run just the factory electric fan on the condenser as long as you get a tune or run a standalone controller. I would still recommend the v6 fan since it’s shrouded which does help it draw more air through the radiator.So after reading all this, I can just remove the mechanical fan on my 2018 and be ok? Not looking to drag race or anything.
