It's all listed or linked in the first 5-6 posts.
@patriot07 (& others) ... Ultimately it will depend on the trim level/radio setup of the 17 truck you get and what you will need... it can be done if planned correctly.
There's a reason, why I don't have a click/buy now website for this because I often need to talk to the customer and figure out exactly what they need to get everything setup/working correctly the first time for the particular truck setup they have.
Easiest to more involved :
- 17+ with factory 8.4 and Dual Zone ATC.
(swap radio, hub and hub harness. No programming changes)
- 17+ w/factory 8.4 & Single Zone MTC.
(Swap above, & add Single Zone ATC wiring, sensors & programming)
- 17+ w/factory Ra2/5.0 BT/handsfree calling/mics in headliner.
(swap radio/bezel, hub, hub harness, conversion harness w/ATC & sensors, 18 module)
- 17+ base with RA1/3.0/ * NO MICs in headliner/No Handsfree BT calling.
(swap radio/bezel, hub, hub harness, conversion harness w/ATC & sensors, 18 module ....
... * Add mic Reroute for 13-16 mirror with mics support 13-16/13-16 Mopar Mirror harness & Mirror with Mics, or *possibly future headliner mics/harness, Camera reroute harness if BuCam display on mirror )
Note:
- 2500/3500's also require fan/resistor conversion harness and 7spd fan resistor.
(Our fan resistor harness is plug n play... No connectors to re-pin)
- 14+ 1500's (only) also require part 2 ATC humidity sensor/harness to complete Single Zone ATC.
- Single Zone ATC requires BCM programming changes using AlfaOBD or OBDgenie. (Dealer can't do it).
- 2013-16 trucks won't require mic reroute, since Mopar mirror harness & mirror with mics cam be purchased/installed directly.
* 18 HVAC module (vs 13-17)
* 14-18 ram 1500's (& 19+ Classic) have a variable displacement compressor (typ. associated with the 7 speed fan)
>> 14-17's w/RAx = 68268186Ax HVAC module (ie RA4 Radio)
>> 18/19's w/UAx = 68366552AA HVAC module (ie UAQ Radio)
* 13-18 ram 2500/3500's (& 13 Ram1500) have a fixed displacement compressor (typ. associated with the 4 speed fan)
>> 14-17's w/RAx = 68105017Ax HVAC module (ie RA4 Radio)
>> 18/19's w/UAx = 68366553AA HVAC module (ie UAQ Radio)
& the current thinking is to match the HVAC module to the 8.4 radio year, but there have been several HVAC Blend/Temperature issues with the UAx radio upgrade that are fixed with the ATC Mod.
M² Mods.
