The new FE11669 Endurance filter has an all synthetic material instead of a blend like mine, but, according to the box, it's made in China instead of Brazil.
Wix xp was the last ones i believe. The vp racing is made in usa as far as i know so maybe thats the last one. Alot of the element filters are made in south korea i thought toWhat this says to me is the filter element material is made in China, and assemble into canisters in the US for the spin-on filters.
I'm not sure any glass media filter is made in US anymore. My motorcycle filter is the same thing.
12v cummins?The 7.3 lifter problems were supposedly remedied fpr 2023, but there are lifter problems appearing on 2023 and 2024 models. I still have an older Ford pickup, and have been a member on a Ford Truck website for 20 years, so I've been keeping up with this.
There are plenty of deniers, but the evidence points to them still having problems.
Didn't want an EcoBoost or Coyote, no GM truck after driving our low mile shop truck at work. It's very uncomfortable to sit in after an hour.
So here I am in my Pentastar truck, and loving it. The only truck I've been in that is as comfortable is the 1994 2500 Ram I also still have.
488 CI, 8.0 liter, V-10. Smoothest engine I've ever owned.12v Cummins?
I am with you on the 1500 Pentastar RAM. I needed a truck to travel in. I am 6'3" and 215 pounds. It is extremely comfortable for me to travel long distances in. And, being a truck the Commodore can bring along anything she wants for 3 months in Florida during the winter as well as 3-4 months in Newfoundland during the summer. I ordered my 2017 Laramie as a stock production with two options. LSD and long range fuel tank. On several occasions I have traveled just over 700 miles on a fill up and the truck has plenty of power for what we use it for. I will say though like you and your older truck, my 1988 C-3500 GMC with bench seat is just as comfortable to sit in. It only lacks in the amenities. And of course it has the stiffer ride of a one ton.The 7.3 lifter problems were supposedly remedied fpr 2023, but there are lifter problems appearing on 2023 and 2024 models. I still have an older Ford pickup, and have been a member on a Ford Truck website for 20 years, so I've been keeping up with this.
Gotta show my ignorance. What is the pedal to the floor and crank with no ignition thing? Is there some way to avoid ignition while cranking the engine thus getting some sort of prime? I guess I might be lucky in that the vast majority of my miles is long distance driving. At 72,000 miles and still under 100 hours idle time I guess that equates to low number of dry start ups. I briefly gave the Baxter set up some thought but decided to keep going as is.It does gripe me that the only place I can get the full synthetic Fram is at WallyMart.
From reading and research this morning, there seems to have been a race to the bottom with all oil filters.
I want good flow and good filtration, with flow being high on the list because of the lack of an anti-drain back valve on the Pentastar, leading to dry, rattling starts after sitting.
I always press the throttle to the floor and turn over the engine two different times for appx 5-8 seconds each. I still get rattle doing this, just not as long.
There is a kit by Baxter to supposedly stop this by adding a spin on oil filter, but it's more than I want to spend to put extra weight on the oil leak waiting to happen oil filter housing of the Pentastar.
I think the Pentastar is a great engine, buy why they did the oiling system the way it is doesn't make sense.
Yes, push pedal all the way to the floor and turn the key, you will see the engine will turn but no ignition. Very few people know about this, in fact it was probably ten years or so before someone brought it up here.Gotta show my ignorance. What is the pedal to the floor and crank with no ignition thing? Is there some way to avoid ignition while cranking the engine thus getting some sort of prime? I guess I might be lucky in that the vast majority of my miles is long distance driving. At 72,000 miles and still under 100 hours idle time I guess that equates to low number of dry start ups. I briefly gave the Baxter set up some thought but decided to keep going as is.
Pedal to the floor is the clear flood mode,i think it kills the injectors so they don't pump more fuel into an already fuel flooded engine.Gotta show my ignorance. What is the pedal to the floor and crank with no ignition thing? Is there some way to avoid ignition while cranking the engine thus getting some sort of prime? I guess I might be lucky in that the vast majority of my miles is long distance driving. At 72,000 miles and still under 100 hours idle time I guess that equates to low number of dry start ups. I briefly gave the Baxter set up some thought but decided to keep going as is.
It actually works. The first time I did it, I held my breath and clenched my teeth, but it does work!Gotta show my ignorance. What is the pedal to the floor and crank with no ignition thing? Is there some way to avoid ignition while cranking the engine thus getting some sort of prime? I guess I might be lucky in that the vast majority of my miles is long distance driving. At 72,000 miles and still under 100 hours idle time I guess that equates to low number of dry start ups. I briefly gave the Baxter set up some thought but decided to keep going as is.
I'm an inch of being 50.... and I love that I can excuse myself from the remembering requirement!I can't seem to remember to shut down @ high idle to leave oil in the gallies.
I can't even remember to bring the key fob with me out to the truck.
