Ramsportrocks
yesterday went to start my truck and found that the battery was down to 12v and wouldnt start the truck..
did a load test and battery went from 12v down to about 7... jumped it and got started and ended up with a check engine light on...
went and picked up a new AGM autocraft platinum 850CCA battery from advance auto, swapped it out and of course the truck fired right up and this time with no check engine light.. NOW here is the kicker.. remote started it this am and when it started up the truck moved forward a little bit and YES it is column shift and in park... took it for a drive to go pick up handgun permits ( sucky NJ where you need a permit to sh*t) and while it is shifting fine it doesnt seem to coast as i roll out of the throttle like it used to.. feels like it is in a gear lower is the only way i can describe it..
at the end of my jaunt around town i hit the button on the column shift and set it to 6th ( 6 speed ) and all seemed to be well on that mode.... still no check engine light..
i do have a superchips tuner and im running the 87 octane economy tune but i dont think that should make any difference after the dead battery..
any ideas???
any ideas???
