does a ram 3500 diesel more or lesser mpg than ram 2500 diesel? How's their differenc
The hippie
cummins
does a ram 3500 diesel more or lesser mpg than ram 2500 diesel? How's their difference in terms of mpg?
xrsman
Ontario
3.0 Ecodiesel
No it'll be the same
Sent from my SM-G920W8 using Tapatalk
14hemiexpress
Texas
6.4l
Depends on the rear axle the 2500's have the 3.42 axle some 3500s have 3.73 or 4.10 and that could yield some difference in mpg but it really shouldn't be huge differences. The main difference between the 3500 and 2500 is the rear suspension the 3500 has leafs and the 2500 has coils witch have a way better ride quality but far less payload. It just depends on what you want to do with the truck as to witch one to get.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
What he said ^^
To clarify that, all SRW diesel 2500/3500's come with 3.42 gears. 3.73's or 4.10's are only availbe in DRW diesel trucks.
Andy578
Ontario, Canada
2014 Outdoorsman
pretty sure it's mostly the same but it'll depend on the options. i'd imagine a dually is gonna use extra and 4x4 loses a little
14hemiexpress
Texas
6.4l
What he said ^^
Not saying your wrong but on Rams build site the 3500 standered is 3.73 and the 4.10 are for duallys and 3.42 is a option but not standered.
We all know how unreliable Rams site is and how often they change standered features.
xrsman
Ontario
3.0 Ecodiesel
True but I'd imagine he's comparing an apples to apples truck in 2500 to 3500
Andy578
Ontario, Canada
2014 Outdoorsman
should be about the same then. there's probably a little extra weight that will cost a little but i think it's really just the suspension so probably not enough to really notice
brandonjansen
That's because standard them come with a Hemi, not a Cummins. With the Hemi you can get 3.73's. Once you select the Cummins the only option is 3.42 unless you select DRW. Then 3.73's and 4.10's become available again.
Really it's stupid... the fact that you can't get 3.73's or 4.10's in a SRW Cummins anymore is completely ridiculous IMO.
2014StormTrooper
Aggieland, TX
2014 Ram 2500 Longhorn 4x4 2003 LY Evo VIII ER Built 2.2L
6.7 CTD / 4G63
My 2500 Cummins averages about 17mpg with mixed driving, which is way better than my 1500 that only got 12 lol
T
The hippie
cummins
My 2015 ram 2500 crew cab 8ft bed 2WD is already 3.73
Goodie1990
